New to the forum and figured I would share an easy thing I whipped up. Also curious if anyone else has tried to do cabin air filtering and if maybe there is a better way of doing it. I tried searching and haven't found anything so figured I would post it up.
A little background. A couple weeks ago I was out on Yellow Cat Flats with some friends and after about 15 or so minutes I kicked the fan on and was blinded by the amount of dust that came pouring out of the vents. After some searching I found a few threads that mentioned the lack of filteration but couldn't find anything as to rigging something up to help or solve the problem. Not to mention the annoyance of having to clean the interior and all of its contents of the layers of dust that build up.
I wanted to use a small box intake filter on the intake part in the first pic but that proved to be a pain in the butt to get to. If anyone has the measurements for the bugger that would be great. I would still prefer to put a filter directly on the intake.
After trying to measure and fit some filters unsuccessfully I decided on going with plan b and throw some filter media on the vent covers. I went with a 16x25 Filtrete Advance Allergen house filter for 16 bucks. I figured that would give plenty of room for errors and if it works I would have a ton to change the media out. I did a water test on is since it is in an area that it will get wet. The water actually beads up and off the media. I left it submerged for about an hour and it didn't soak through so I think it will hold up pretty good.
All and all I am surprised at how well it worked. I went out on the Pony express trail and had three vehicles in front of me kicking up dust. Much more then on Yellow Cat mentioned earlier. I specifically had my fresh air and fan on for the trip out and left it off and would turn it on every 25-30 min to see if dust accumulation would be a problem. To my amusement I didn't even have to clean the interior of the vehicle like usual because no noticeable dust go in from the trip.
Pix are attached and hopefully it can be a 20 min mod to help other members from having to clean the dust from the interior and everything inside the cab during and after every trip on the trail.
