Wanted CA FJ40 Cooler Type Radiator #16400-61030
California
  1. 40 Series
Looking for late model FJ40 AC type radiator. Slightly wider than the non ac radiator in the later models. If your AC type radiator is housed in a 22" U shaped radiator support then that is the WRONG one for me. Earlier AC version radiators were of the same size as non AC radiators, width wise.
good luck in the search
did you try SOR?
can yours be recored?
a guy in the tech section gave up looking and used a non a/c rad and used strap to make up the difference in width,
non AC were 19 3/16 wide, AC were 21 3/16 wide, do you have evidence of a wider AC radiator?
ok, we are measuring differently, I was measuring the radiator itself while you are measuring the support. I have the radiator you seek. Freshly re-cored by the local radiator shop in Wilmington. Selling it with the matching support and shroud.
From Left- Late 1979 early 1980 FJ40 with factory AC condenser and 22" rad. support.
Middle- 1981 FJ40 non AC and 22" rad. support
Right- 1983 FJ40 factory AC and 23.5/8" rad support
I thought there are just 2 versions OEM rads A/C and non A/C
I'm thinking the one with the condensor on it isn't an OEM A/C setup, or maybe someone installed on a non A/C rig, or dealer install
my 1980 40 with A/C is the wider version which goes along with the different battery mount,
I measured things years ago and IIRC all the width was gained on the passenger side of the mount and shroud, thus needing the special offset lower hose
Most likely dealer installed Nippondenso unit on non A/C rig.
I don't suppose you'll part with just the radiator. Do you have a price in mind?
Bump
