Bumps and forklifts ... (1 Viewer)
Ok , let me get this straight , so when I walk up to a perfect stranger with a forklift , I can explain my madness to them . :D
- Lift each tire individually
- Raise it till it stuffs
- Measure distance from existing bump to axle tube
- Fashion an extension based on that measurement
If this is correct , then I have a few questions .
- How much error should I build into my extensions ? IOW's at stuff , when I measure , should I add another 1/4" or so , so that I assure that I never run the risk of having the MT's hit the flare , ripping it off ?
- This is a very controlled flex , so again in terms of error , what sort of real-world flex might push me beyond the limits of my bumps ? Or will my initial error addition to the extension account for that added flex ?
I just got my front bump stops in from Dan , so I'm looking forward to getting them on , and having extensions made all around .
On a technical note with regards to making the extensions , would 2x2 square stock do ok ? If I require more than 2" , I thought I could place 2x?" flat stock between the frame rail and the 2x2 square ; as required .
Is this all sound ?
TY
Nope, nothing like that has ever been attempted or even thought of! :flipoff2:
im with reffug....your crazy...
just got find a loading dock brotha :)
T, no needum forkie. :idea: Just find some rocks, a high berm, steep narrow ditch etc. Keep in mind whatever you do you'll need to allow for some increase in a real wheeling situation.
You should have told me you wanted some bumpstops. :slap: I still have a few of them in the garage and would have glady sent them to ya. :dropkick:
Yes, measure, allow for some error then lower. In the front, I used 2"x2" tubing and in the rear 2"x3". It ain't rocket science on the drop piece, just whatever works.
There's a huge place across the place from my base . Funny as hell cause the forklift has one of those spoilers on the roof .. you know the angled ones like on the alcohol race cars . Figure based on that the guy might be good humoured , and game to help me out .. I'll drop by in the next week .
TY
So Junk , did you lower them 3" in the rear then ? May be obvious from what you said .. just making sure . In case you layed the 3" section against the rail for some reason .
I'm trying to avoid the ditch because I can't see what is coming close to touching that way .. with any control . With my luck I'll glide down into the ditch and rip off my :princess: flares in one smooth movement .. haha
TY
I supplied the TOP SECRET 1993-ONLY FRONT bumpstops to our shaven friend....:D
Cdan, I have seen 2 94s that had them too, but they were early 94s if that matters.
For the record, I used Energy Suspension bumpstops in the front :D
And they came from a long , long way away .. :D
Ask Dan how he knew the part #'s to call over to Japan ... straight out of the customer service guru manual ... :beer:
Arya Ebrahimi said:
My '94 has bumpstops up front...
Mounted to the bottom side of the frame rails directly above the axle housing?
I was waiting for that ... ;)
Dude , the front look like the rears .. they are bolted to the frame rails , and come between the frame rail and the axle tube .
TY
Not inside the coil ..
See in this pic how the fron tcoils are 'outside' of the rails ? Well the bumps mount directly below the rails ... essentially beside the coils .
Cool ... you're lucky . Most of us have to get them from Japan , or buy aftermarket on the continent as Junkster has ...
TY
Arya Ebrahimi said:
Correct, I have bumpstops in the coil AND on the frame above the axle housing...
Hmm,
I have not personally seen them on a 94 but since 93 and 94 are VERY similar I am not too surprised. They are not present on 91-2 or 95-7 and they ARE NOT listed in the parts catalog, period.
