I must be having a brain melt down becasue I cannot understand how a new set of T bars allows for a lift without doing the exact same thing as cranking up your OE's. In other words, your A arm in the 100 does not change in terms of location so all that can occur is a lowering of the A arm which results in 1- lift and 2- Cv angle. The diff drop kit will take care of two but nothing will take care of 1's consequence on travel or droop.
Am I right on in this? Has any of you with the new t bars adjusted your stops or are you just trying to solve the issue of stuffing the tire versus rubbing?
Thanks.
Thanks.
