Could someone define bump steer and what causes it. I dont think I have grasped the full concept of it. thank you.
Howdy! You've got it pretty good. Rigs with lots of lift tend to have the steering box much higher than the axle/steering arm, so the drag link sits at a very steep angle, compared to the stock arrangement, which is almost flat/level/ parallel to the axle. As the front suspension on a lifted rig compresses, without moving the steering wheel, the drag link moves and pushes the steering arm to the right( on a LHD rig). More bump = more steer. Big bump at speed makes the rig veer to the right. Can be a bit of a problem/surprise. Typical solution is lower steering box and /or pitman arm. Raise steering arm and /or install a high steer kit.Bump Steer
When your suspension flexes - your tires steer without the steering wheel moving..
minimize this by keeping your drag link parallel with the axle, (Drop pitman, ect)
ill let someone with more experience on Linked suspensions explain further..
with a 3 link, im pretty sure the goal is to have the panhard, or track bar parallel with the drag link, and mount in a similar fashion, IE (LHD axle mount on the passenger side, Frame mount Drivers side)
I have already built my suspension and noticed the rear steer issue. thats why I was wondering if that was part of bump steer.
) it's I " feel " in mate 80 series something close to bump steer .. but in the rear ..
