Cool bit I came across. TJM just went way up in my book seeing actual impact analysis and engineering going on behind the scenes when they create a bull bar. Doesn't hurt that the bar on Shauno's new 200-series build looks great.
I will let you know. I just finish installing mine this past weekend. Just some driving around town so far. Don't have any data on MPG or how it feels on the interstate yet. I still need to adjust my BP-51's for this addition.Man, makes me want to get one. I have 2 issues: rust, do these rust in salty wintery areas? How bad does it hurt speed? For example I like cruising at 80mph and I dont feel it in stock 200. I imagine with this on you feel like you are going 80mph because of the amount of wind pushing back. Anyone want to elaborate on their experience? This is the one mod I have been itching to do but get cold feet last second. My cruiser feels naked without one but I dont know if Id like the drawbacks.
This is a late model. MY19 same as your MY21.Good looking bumper. I've been considering one on my 2021. Anyone have one on a late model year they can share pics of? Thanks
More pics please.I will let you know. I just finish installing mine this past weekend. Just some driving around town so far. Don't have any data on MPG or how it feels on the interstate yet. I still need to adjust my BP-51's for this addition.
I will post some more in a couple of days and do a little write up on the install.More pics please.
Looks great. What did you do to suspension to accommodate the extra weight of bumper and winch?
I have the BP-51. I believe I have a 20mm preset, which is ARB recommendation for a bumper and winch, so I adjusted the rebound and compression on the shocks. I set them to 8 and 6 on the front and the back is at 7 and 5, with the 23 springs in the back. I don't have a bumper on the rear yet but I do have a Trekboxx and fridge in the back with a fair number of tools and other gear.Looks great. What did you do to suspension to accommodate the extra weight of bumper and winch?
Yes the preset for a bumper and winch is 20mm. Mine was set at 20mm already so I did not need to change that. I have the 23 springs in the rear. I did not take any measurements, so I can not comment on any change in height in the front. Your set-up is basically about the same as mine. So far I think the 20mm preset is about right. I will need to play with the rebound and compression setting a little to fine tune it. The fronts are easy to adjust the R&C on. The rears are little bit of a pain.How is a the BP-51 standard 20mm set handle the weight ? Do you need more or Less Preload ?
Its a little bit of a pain in the butt you have to compress the spring on the BP-51 shock then adjust the lock ring .
I’m BP-51 , TJM , Bud built with stainless skids , warn 9.5 syn , going dual battles .
My understanding the BP springs are 750 lb springs and the BP are preset at 20mm for the bumper and winch .
I will most likely do a Dissent rear bumper. I have never had any rubbing with this tire and wheel combination. The Icons have a 25mm offset. I don't think I would have a problem going to the next size up and most likely will with the next set of tires.Just about what I am going to run , I have 2723 rears as well , I’m doing a rear bumper just waiting on Slee to restock , my back up choice is a Kaymar .
I see your running BF 285/70r17 how much room do you have with TJM tire wise , what wheel offset ?
I’m doing the RW just have to narrow down what tire size , I know the BF’s run A little small .
Ok…because their bumper and slider and how they connect looks just like ARB.No, they are different companies.
