Picture the typical 2" OD square bar that fits in a hitch receiver. I am thinking about making a "coupling" for those using a 2" ID square tube like the typical receiver tube. Applications would be to extend an existing bar for a cargo basket, or to have a modular ending system where I could change the attachment coupler on a 2" OD square bar trailer tongue. So, going from 2"OD to 2"ID to 2"OD. Being able to dismantle the thing easily would be a plus (i.e. hitch pins over bolts).
I'm trying to avoid having to do custom machining and welding, but I'm thinking that using off-the-shelf tubing like the usual 2" ID receiver tubes may be problematic. Seems like there is a fair amount of tolerance between those and the typical 2" OD bar, so a coupling would be sloppy with only one pin or bolt on each side unless I'd use tighteners of some kind. I suppose that having 2 pins on each side would help with that but I don't want too much stress on the pins, it should be on the tube instead. A wedge maybe? The tube would have also to be pretty thick to avoid damage I would think, some of the 2"ID receiver tubes I see are downright flimsy.
Anybody built something like this successfully with off the shelf parts?
