buggy dreams (1 Viewer)
Maybe an Aqualu frame with speedglass :smokin:
my steel frame is beat beyond use....BUT the polycarb that's in there saved a TON of weight....an alum frame would be a must :)
Doesn't T-fab build his 100-proof chassis with a cowl and windshield frame option?
I don't know if they have a windshield option, I can't remember. I'll let ya'll know tomorrow, I'm stopping by there while I run errands in Reno.
OPW's rig from OZ
OPW's rig from OZ
OMG, How is that type of articulation possible w/ out rolling over? It doesn't look like coilover suspension, Hydrolics and a play on sucking down the rear while pushing up the front?
Any info on video of this rig???
Check this out if one has the resources Sam is the guy to do what you want.
I've seen this rig and it is sweet, the suspension can be tuned for rock crawling or desert racing. I'll try to find some more pictures of it on hardcore trails.
We competed against this rig at TTC. The rig is unbelievable but driver & navi are probably best in OZ.
Here is the travel ramp clip also check out the ramp figures below the vid.There are other vids on the site during the same comp.
Basically the travel ramp stage you had 3 minutes to get as far up the ramp while keeping 3 wheels on the ground.
Tuff Truck Challenge 2009 Team OPW Video - Snake Racing - Trick Off Road Componentry for your 4x4, 4WD vehicle
brooksy
Wow thanks!!! that is what I wanted to see...
WAY LATE on this one.
narrowing from stock the cowl ? ie narrow windshelid frame ?
lose the glass and wiper stuff, saves a ton of weight
run quick pin style outside the cage, then if your worried
you can setup for a repin on the inside of the cage. rubber
isolated will allow movement for HARD rolls, or super cage
and hard mount. I am a firm believer in something for
at speed driving of any sort.
What is the LENGTH of the aftermarket hoods ?
i cannot
find the narrow TC length anywhere and thier site is down.
i got he 48" at the cowl. searched and got this thread.
