OEM vs. AFTERMARKET
Well, you all DON'T EVEN wanna get me started...I'm such a lunatic about OEM, and despise AFT. Parts so badly...I'd postpone a needed rear brake job just to afford OEM over anything else. I've fallen for all the "GUARANTEED like OEM" QUALITY GUARANTEED,etc.... I understand this: There's a TON of money to be made marketing way cheaper aftermarket parts. Personally, I now just do without. Here's a couple experiences:
An old 1963 FJ40 i had:
Problem: Ugly original window regulator...too lazy to blast and paint it...so:
"Solution": (note the quotes) was to order inexpensive (that's kind for CHEAP) aftermarket for yours truly.
RESULT: The brand new aftermarket window regulator LITERALLY CRACKED (gears etc)...due to the high resistance in the window channel...shortly after install. I think that only in a brand new window channel with very little resistance would they have lasted. Closer inspection revealed their DIECAST (think hot wheel, mattel ,etc) metal construction. Ended up painting and putting the OEM (30+ year old part) back on!!!!
PROBLEM: OEM toyota door lock/regulator rattles cause its almost 30 years old!
"SOLUTION:": Gave the Quality guaranteed AFtermarket a shot...against my better judgement...but HEY, its $100 dollars CHEAPER!!!! right??? a PITA to put on too...
RESULT: After a few weeks or so, I got locked out my rig. Been fighting the door since...seems the springs in the cheap aftermarket ones (SOR, CCOT, they ALL CARRY THEM) are weak...there is nothing physically broken about it...they just plain SUCK...I'm going to sleeve and put my original back on...its actually better than the NEW AFT. ONE...seriously.
In short, I'd only CONSIDER using the COSMETIC stuff...like the reflectors for instance...that's it. Some things, you have NO CHOICE on (lift springs, etc). And other things, there is no TOYOTA OEM version of...
Finally, if anyone wants them, I have Aftermarket side mirror and reflector, and even a sending unit (that I'm AFRAID OF...really...as in SCARED...) that are FREE. I can't even stand to look in the ONE aftermarket mirror that CCOT gave me with an order...the poorly cut glass bothers me...I can see the cut glass sticking out the plastic...LMAO....I'm just gonna keep my old OEM ones until I get NEW OEM ones.....
WHEW! I'm threw venting...thanx guys...flame me later...I'm out...
Mike
