CharlieS
GOLD Star
Hi All,
I managed to snap 3 of the 4 sway bar mounting bracket bolts when removing it to install my lift. they broke off flush or below the surface, so there is no hope of getting anything on them to ease removal.
So, the logical thing to do was to just remove the sway bar until I could find time to fix the problem. While removing the four sway bar bolts on the rear axle I managed to break two of those too. Nice.
(edit... I did use tons of PB Blaster and the bolts all moved quite a ways, but when the threads got to the section that extended up past the captive nut, they got bound up on corrosion and the torque from me wrenching snapped them off. The good news is that they were the only fasteners damaged all weekend!)
I assume that I am going to have to drill and tap, yay. Worst comes to worst I'll cut them out and weld in some captive nuts. Still a pain in the neck job any way I cut it, and I won't have time to do it for a couple of weeks.
I have two questions:
1) anyone have any other ideas for getting the bolts out of the holes? Other than drill, pick, tap or cut out and weld in new nuts?
2) is there any danger in running without a rear swaybar? I assume I've added some oversteer by removing it, but I am not aware of any other issues/dangers. Am I wrong?
Thanks everybody.
Charlie
Thanks everybody.
Charlie
