- Joined
- Apr 6, 2010
- Threads
- 12
- Messages
- 117
Went out wheeling yesterday and snapped my rear pinion shaft in half at the front splines. I was articulating a bit with the rear (approx 1') and going up a steep short climb to a bypass started to spin, backed about 2 feet took another run at it and then POP. Fairly certain I was just to heavy on the right pedal but was curious if anyone had other ideas for other things that might have caused it? I was kind of thinking axle wrap binding a u joint but i guess that would have broke something on transfer case side not axle side. Curious if there is something else I should address after I swap the third member. My rig setup is currently 383 SBC 4 speed 3.73 gears 32" all terrains SOA. I know its quite a bit more power than it came with but with 32's and stock gears didn't think I'd break there.
I have one free 4.11 third member so probably just going to change to a couple of those until I have enough $$ to re-gear. Anyone know through what year I can swap out a rear from the newer cruisers? Also for the older 40 series, 78+ should be fine spline and swap right in correct? Last question, is there anything that can be done to prevent the front from snapping? Thanks for the info
