Greetings,
I have been trouble free for so long I forgot the hundie is not perfect. going slow, turn left or right sharply and brakes come on hard enough to stop a slow roll. Then sometimes followed by a jecrky start, even spin a rear wheel in the dirt. Going highway speeds never noticed anything (relatively straight roads easy turns).
My first thoughts were loose wheel, stuck caliper, loose wheel bearing, failed suspension part.
pulled all 4 wheels and have very worn pads 1/8 -1/4" but no stuck calipers ie wheels turn by hand.
Checked suspension parts- all intact if tired. One slightly loose wheel bearing- tightened that.
checked if in 4wheel drive- no. Pushed little image of wheels button and no change either way. Brake fluid ok.
After all that -- still the same: truck will stop from slow coasting speed when wheel turned tightly .
I could not find anything on MUD but found a very similar issue on Diesel Place; the problem was fixed with new Hydro-Booster, whatever that is. Another said it is a flow control valve in the booster.
Is it the brake booster? Stumped-- Help!
Steve
Steve
