Hi all,
I'm going to purchase the disc brake conversion from MAF for my '72 FJ55. however, while i'm at it, i'm thinking about redoing the rest of the brake system. the lines (hard) are pretty gnarly and the master cylinder is also looking pretty hagard.
see below:
I'm looking for some recommendations, i'm not a brake expert by any stretch.
I'd like to replace just about everything while i'm at it.
couple questions:
-> i see that it has an old vacuum booster on it. is that the same as modern power brakes? i was seeing here: Toyota Early FJ40 45 Land Cruiser Brake Booster Adapter - JTOutfitters that they sell an adapter for power brakes, but do i already have them?
-> if i replace the master cylinder, should i use the same one, or is there a better version available?
-> i want to replace most/all of the hard lines, what size should i use? do i need to stick with 10mm?
what would you recommend i put in here in place of all this stuff to go along with my new disc brakes?
see below:
couple questions:
