AussieHJCruza
Supporting Vendor
- Joined
- Jul 8, 2013
- Threads
- 64
- Messages
- 2,992
- Location
- New South Wales, Australia
- Website
- www.completecruisers.com.au
Good Afternoon everyone, hoping for some input from the brains trust please:
02/86 FJ62 Sahara, going through the laborious process of getting a modified vehicle signed off by a vehicle engineer and registered.
I'm having issues with the brake pedal effort required, she passes the brake test with 35s, however max allowed pedal effort is 850 newtons and I'm at 961N to pass the test.
Drums are recently machined and new rear shoes, and front has fairly recent pads, just run of the mill aftermarket stuff. Caliper pistons aren't siezed. Handbrake passes the handbrake test so I'll assume that the drums are adjusted properly.
Soft lines are rubber but all look decent.
Brake booster is week-old Advics 80 series dual diaphragm into stock 60 series master.
I'm looking for suggestions on what I can do to reduce the pedal effort, a few thoughts below but would be interested in everyone's experience please.
Options:
1) More aggressive front pads
2) Braided lines - no idea if this will make any difference
3) I can get a further brake booster upgrade, however I'm reluctant as these are larger in diameter again than an 80 Dual Diapragm and because she's a Sahara, will foul on the clutch booster. Would like to avoid replumbing the clutch hardlines and relocating the master if there's any way I can avoid it.
Any thoughts on tyre pressures effecting this? Currently at about 30 psi for ride comfort.
Thanks in advance for your input and a couple of pics, just because.
Cheers
Options:
Cheers
