Pad Build Up Causes Brake Pulsation. Turning Rotors removes Pad Buildup.The front pads have a different retention mechanism between the 460 and 470, so you'd need to also get new pads if you do the 460 upgrade later on. EBC pads also have to be bedded to each rotor (they have a abrasive first layer on the pads), replacing rotors usually also requires a pad replacement. I made the mistake of putting a set of EBCs on a thin set of rotors in 2024, and had to buy a whole new set in 2025 when I did the rotors due to them being warped. So, I'd suggest measuring your rotors first to make sure they have plenty of life left.
Regarding fluid, I flush the entire system every 3 years or so. When compressing the caliper pistons to make room for new pads, I let the excess go back to the reservoir.
Brake Pedal Pulsation
Everyone thinks they need to Upgrade the Brakes on these Vehicles, but Toyota did not Fumble the Brake Design on these Trucks.
These trucks are Quite Heavy, so they do Wear Pads Quicker than Cars.
