Brake lights stay on - fixed
CT
My brakes lights on my LJ77 stay on even after turning off the engine.
I ended up disconnecting the battery and I'll look at it tomorrow.
This is new one for me, never had it happen.
Only think I can think of is the brake light switch on the pedal is bad or frozen.
Any other suggestions on what would cause the brakes lights to stay on?
Thanks
Fixed:
Switch was ok, it was the rubber/ceramic insert that pushes the switch in.
Weird set up, there is a hole in the metal bracket on the brake pedal. Not sure why the bracket has this hole instead of being solid.
Anyway, the rubber/ceramic plug fractured (old age and cold?) exposing the hole, so the brake lights were in the on position all the time.
Covered the hole with a small piece of metal and glued it in place.
Problem fixed.
