I'm troubleshooting a dash light that is always on and have two questions:
1) does the brake fluid reservoir float "open" or "close" the circuit when it is lifted (e.g. when fluid is at correct level)?
2) does anyone have a wiring diagram for this circuit or know where I can find one?
I picked up a 60 series a little while ago and the dashboard "brake" light is always on. I attempted to troubleshoot it and I think I may be fighting multiple faults. About all in could verify was that the parking brake switch itself works. Checking resistance across the two wires leading to the fluid reservoir float doesn't seem to change when the float moves (circuit is always open / resistance off the charts). If I unplug the float switch and short the plug leading to the wiring harness, it doesn't change anything, regardless of position of the handbrake. Same if the float is unplugged and not jumpered.
Naturally, I removed the bulb from the dash
Any other thoughts on how to figure this out?
