Brake Booster Pump vehicle cross reference inquiry
Garner, NC
I had the dreaded ABS/Brake/warning buzzer this morning.
I know I can order parts through Ebay, but I was really hoping to find the part locally so I can get back on the road. Does anyone know of which Toyota vehicles used this same part number?
47070-60010.
Thanks in advance!
@gatormark91 do you have the list? I know we planned on doing this soon.
This is the booster with accumulator only. Not the whole master.
According to toyoDIY, 47070-60010 is used in:
N. America 02/1999-09/2006 TOYOTA TUNDRA, GSK30,UCK3*,4*,VCK30,40
Europe, N. America 11/1995-07/2002 TOYOTA 4RUNNER, RZN18*,VZN18*
In addition to all years of LX470 and UZJ100.
If you look at the booster pump with motor alone, 47960-60010, you can add 95 to 04 Tacoma as well. And that goes for the accumulator alone also, 47950-60010. So what is different on the Tacoma, when both the pump/motor and the accumulator are the same? Even the power cable is the same.
Now I’m not sure what to do. I checked the ABS codes and got a 56. Accumulator low pressure malfunction. Based on diagnostic chart, accumulator, pressure switch (PH or PL) , hydraulic brake booster pump motor.
My truck had the booster pump motor buzzing in the mornings when it was cold, but since it warmed up, it’s been pretty quiet. Still think it’s the accumulator/ pump but I may need to test the switches too if I can figure it out.
I've been battling this same problem. Intermittent pump noise followed by the high pitch alarm.
I had the motor looked at by an old electric shop in town. They said the motor itself is fine.
It definitely sounds like a seal is letting go and not keeping the pressure, triggering the alarm.
I ordered one off eBay that was advertised as fitting 98-2007 lx470. It didn't for my 2003.
The part number was listed as 47070-60010.
It was much smaller and didn't fit.
I'm still looking for the right part number.
I believe that either the accumulator is bad or the pump itself is bad.
Does anyone have part numbers for the pump and accumulator?
I checked on camelback toyota and found 47960 60010 for 03 LC should be the same for LX. $1252.00. Looks like the pump and the accumulator come separately as well as both together and much cheaper
Accumulator for 03 LC is 47950 60010
Does the pump come with the motor for 03?
I dont know if the accumulator or the pump itself is bad. The motor is good.
I heard it is best to replace all together. There is a thread going on about this right now.
Try googling camelbacktoyotaparts and then select 03 and land cruiser. Go to brakes and hydraulic componenets to see all these in detail.
Thanks! Super helpful. Someone listed the wrong part number for the wrong years and I think it's been copied and pasted a few too many times.
Camelback has 47070-60010 (booster assembly with accumulator and motor) listed as fitting a 2003 land cruiser. This is the one I purchased and it was smaller. The accumulator was a different size and the connections were different.
Right below that they have the accumulator listed as part number 47950-60010.
Below that, they have the pump listed as part number 47960-60010.
I think my problem is a seal leaking. You can hear what sounds like a blow by as the pump is trying to fill. It's always at the very end when the pressure is the highest and intermittent.
