Great work! I just picked up the same laid you have. Ended up getting it for free! Did you replace the three belts ? And if so where did you get them at ?
I'll take a bunch of pics tomorrow to post on here. I just started the cleanup yesterday. Mine has the 5 hp motor on it.I did not replace them. Mine were in decent shape.
What size did you get? Lets see some pics!
Nice looking machine!I'll take a bunch of pics tomorrow to post on here. I just started the cleanup yesterday. Mine has the 5 hp motor on it.
I ran out there this morning before heading to church and that number is 6312. Unfortunately I don't have the taper attachment , I only have the one large 4 jaw. Is the chuck held on by the four bolts and then the plate unscrewed for removal. Also curious what type of paint you used and did you prime first. I'm not gonna get too crazy at first . But I am gonna take the cross slide and carriage off for cleaning. I took the cover off the headstock and all the gears look great though.Nice looking machine!
I see a micrometer stop on the left end of the bed right next to the headstock. Thats a nice find! Does it have a taper attachment? Take a look under the tailstock on top of the way in that area there should be a serial number. That will let you figure out the date of manufacture. Take some shots of the speed and feed plates as well.
Cant beat that for free! I think you will be happy with the quality of the machine. Not the fanciest out there but you can do some really nice work.
Getting back into it today. Really not for sure of the direction I want to take with this. I'm guess I'm just going to disassemble degrease and paint. I'll just repair anything as I go along. A couple my handles are in bad shape. everything appears to be in decent shape other than that. However in the last picture I cannot figure out how to get the feed to engage, these two gears to mesh.
Ok, I got the top gear to now slide freely. I didn't know it had to be slide manually. Probably been a while since it's moved. Now the lead screw is functioning as advertised. Now the lower gear has a spring that keeps it from being engaged. Is that what the stop to the right is for? To hold it to the left thereby being engaged? Has to repair a couple he does that were broke, so now I know what you meant about the taped dowels... Also, I found your thread on your lathe in practical machinist. What oil did yt? Ok go back with in the head andWith the saddle off the apron may be binding as the weight is just kind of flopping around at that point without the saddle to hold it in correct alignment.
The gear on the top is how you engage/disengage the lead screw. That should slide to the left and right. This is a feature that allows you to disengage the lead when you dont need it.
If you take the lathe out of gear you should be able to rotate the chuck by hand and get the feed rod to rotate around so you can slide the gear into mesh. That is assuming you have the forward/reverse engaged on the headstock.
Ok, I got the top gear to now sliding freely. I didn't know it had to be slide manually. Probably been a while since it's moved. Now the lead screw is functioning as advertised. Now the lower gear has a spring that keeps it from being engaged. Is that what the stop to the right is for? To hold it to the left thereby being engaged? Has to repair a couple he does that were broke, so now I know what you meant about the taped dowels... Also, I found your thread on your lathe in practical machinist. What oil did you go back with in the head and carriage?you to disengage the lead when you dont need it.
@FJsapper Rad lathe man. I saw you asking about permits for the wiring. Technically yes, Madison requires permits, However I know that myself and other Home Inspectors don't pull permits for residential inspections. Most don't even check anything over 120v outlets for correct wiring. Myself and a few others will, but most won’t. Worse case they spot it in the main panel, and it would only get written up if the installation was subpar wrong/ dangerous.
Because you just NEED one of these now:
Monarch Model K Lathe
Used Monarch Model K :Saws, Drills, Jacks, Etc, w/o Functional Test in Chambersburg, Pennsylvania, United States for sale, inspected and guaranteed. nullwww.govplanet.com
