blown fuse? Won't start, help!
Could someone with electrical/ignition knowledge please call me? My 87 60 seems to have blown a fuse or, but I cannot find it! I am I a store parking lot..
I put the key in and turned it two clicks. Radio came on and I powered it off because I was on the phone. I then tried to start the truck, and nothing. I noticed noinstruments were on and tried turning radio back on, but it is not getting amy power.
Dome light is on, when I turn on headlights there is a constant, fast clicking near pedals...
Help! 360 two oh two 8922
I called Jon. He thinks the battery is dead and was in the process of trying a jump. Had already checked battery contacts and fuses. Was also going to check fusible link.
check the "engine" fuse. I believe that the truck will still run if the fuse is blown but the alternator won't charge.
He got it running. A combination of shorted ground wire at the battery and battery jump did the trick.
how do you have a shorted ground wire?
What he said was a ground wire at the battery was touching the positive terminal- or a positive wire coming off the battery. Somthing like that. Anyways, he is off and running.
