Black smoke (1 Viewer)
Coombs B.C. Canada
I have a '92 land crusier that pushes alot of black smoke when you put your foot in it. I was told that meant it was alot of unburnt fuel? What is the cure?
Thanks Dave
Also check your air filter if it is plugged this will also cause the black smoke but usually is injector related
You can try a fuel system cleaner and new fuel filter as a cheaper option before getting into the injectors. If that does not fix it, the other guys are right on and it's time to check injectors, timing and IP.
K
