Anyone using waste engine oil as fuel?
Experiences please...
andrewfarmer said:Anyone using waste engine oil as fuel?
silvercrusher said:Micheal what are you using to filter the oil down to .5 micron? Is it a circ. system with pump or just gravity drain into a filter? Curious.
Also how does synthetic work or do you have to stay with the dino juice.
sandcruiser said:The reason that black diesel is unlawful in the USA is that the oil is laden with all sorts of nasty stuff you don't want to breathe.
Personally, I'd rather burn cleaner than dirtier.... veggie oil is a better solution than motor oil.
But to each his own, right?
sandcruiser said:I can actually buy veggie oil for almost the same price as diesel now.... around 70 cents/ liter more or less.
I can also get used oil for free from a friend's restaurant. so I'm installing a heated filter next weekend to start running it. Just need another tank now.
Tapage said:liter = 3.3 gal right .. ?
2.10 US diesel gal, is not bad .. here go over 2.80 tomorrow.
tlcruiserman said:Yes I have run black diesel and plan to continue to run it when I have extra oil I need to dispose of. I filter the oil down to .5 micron and do a 50/50 mix with diesel. Works fine you have to play with the mix ratio to get the best results (least amount of smoke).
Cheers,
Michael
andrewfarmer said:How do you filter it - have been unable to source a 1/2 micron filter - the finest I can get is 5 micron...
