- Thread starter
- #21
Good info, thanks!
I stumbled across a shop that somehow filled mine with R12. I think they recover it from other vehicles and use it later.
I would bet anyone hoarding or using R12 in California would be put to death in a solar-powered electric chair.
R134 conversion is the preferred method if R12 is not available.
The o-rings need to be replaced and a different oil is needed for the compressor.
That sounds quite challenging. Also sounds like something I’m gonna have to pay someone to do. For the mean time I think I’ll be content with having a fan. Thanks for the insight Dan. Much appreciated
The part number will be of no use to you as it has been discontinued for years. You will have to repair the existing wiring or hand-build a new harness.Does anyone have the part number to the ac compressor wiring harness? put a new compressor in yesterday but found out that the wiring fronm the AC compressor is no good
Thanks Dan! Would you happen to have the wiring diagram for the AC system ?The part number will be of no use to you as it has been discontinued for years. You will have to repair the existing wiring or hand-build a new harness.
