I've noticed a problem on the two BJ70's I've seen, now including my own. The heater control knob doesn't want to move from hot to cold, but the problem doesn't appear to be the cable. Bolted to the firewall under the hood is a funky looking gizmo that looks to control the heat valve. This control doesn't seem to be working properly. Before taking it apart, I thought of running this by you guys since it's probably a common problem with these rigs and someone might know if the problem is likely to be a frozen valve or the mechanism between it and the cable. Thanks, Bret
