Hey guys,
Last week my little Cruiser decided to strand me. Shortly before it died, I heard relay(s) clicking intermittently underneath my steering column/dash area.
A colleague managed to get me moving by hotwiring my fuel pump cutoff solenoid - not a long term solution, as the truck then cannot be turned off with the key. As best I can tell, the ignition signal is not doing anything. Starter still cranks at START position, and everything at ACC works as it should, but when I move key to IG nothing happens. No filter light, no glowplugs. This makes me think it's something to do with the ignition.
What's weird is that when I voltmeter the contacts on back of the ignition barrel, the IG position is behaving exactly as expected. 24V between IG and input (not sure what it stands for, but called AM in the schematics) when key is at ACC or LOCK, and close to 0V when key is at IG. Is there anything else that could be causing this issue? i.e. a relay in series with ignition signal?
Cheers
Josh
Cheers
Josh
