thanks so much for the input! i guess re-gearing would be last on my list?just finished the truck with the mechanic.. these things were done:
1. tank cleaning, inside scrubbing and re-coating
2. re-layout of fuel lines
3. drum brake cleaning, bleeding and hose change. rear drums were a bit stuck and had a leak.
4. slight electrical work, fixed a ground prblem
5. re-calibration and overhaul of fuel injectors
TOTAL bill
173.91 dollars, parts AND labor.
sorting her out slowly.. noticed a couple of things...
1. when i do a full turn on the steering wheel, the car slows down a bit... feels like the brakes are sticking...
2. At start, the muffler dishes out thick white smoke... but after a while, its all good...
3. The engine pressure starts off at max the gauge, then drops gradually as the engine keeps running..
Ive only managed to run her for about 15 - 20 kilometers at a time.. scared i might break her or something..
any ideas gentlemen? or this is as it should be... thanks
pm sent...kumusta kabayan...sending parts..(3 DUI,4 set of longfield axle,6 pcs Fuel pump 2 set R&P) (PI) this 2nd week of feb just let me know what you want ....
