Hey everyone,
I recently purchased the "bastard child" of Central America down here in Nicaragua, a 1972 FJ40 with a 3b swap (Looks like it is from early '85, guessing from a 70) mated to a 4 speed (not sure what year). This week my clutch engagement point started to feel like it was moving and by the time I made it down my rugged jungle trail back home it seemed like I was down on power, assuming it was starting to slip. Upon crawling underneath it I noticed the slave cylinder was attached to the bellhousing with a custom bracket made of two pieces of angle iron. The one piece of angle iron was bent and started to crack on one side, and the resulting twist changed my engagement point. After some digging on here, it looks like I have the incorrect slave for my bellhousing type, guessing the person who did the swap used the slave from the 72 FJ chassis instead of the different version that is used on the diesels. That looks to be an easy fix, simply need to replace the current slave with the correct one. My conundrum though is it appears my clutch fork is the incorrect version for the diesel slave. My fork is too long to align with the bellhousing placement of the correct slave, and my fork has the hole in the end the slave rod protruded through instead of the type with the depression and no hole that the diesel slave utilizes.
So my first question is this...are the two clutch fork types interchangeable? It looks like I'm going to have to drop the trans to replace the clutch anyway so swapping the fork is no big deal, just want to verify it is as simple as swapping one for the other.
My second question is can anyone provide me with a suggestion/part # on which clutch kit to use? If my motor was from an '83 I'd just assume the motor and trans were a matching set and buy the appropriate kit, but considering my motor is from 85 after they had switched to the 5 speed, I'm not sure if my trans is from a gas or diesel and how that effects which clutch I should use. Is there any way to identify from an external view of the trans what clutch is appropriate? I'm a little "lost in the sauce"...
Finally, does anyone know of a source for a new 3b flywheel? It sounds like the 3b flywheel is stepped and I am not sure if there are any machine shops locally that could resurface it, considering just buying a new one if possible. Has anyone had success with a DIY resurface?
I've included some pics so you can see what I'm up against, thanks in advance for your help!
