Thanks for the tip. I ended up jacking up the tire and then everything moved around freely and I was able to center the bearing and tap the steering rod back on. It went on pretty easy.Pull the bearing out and put it on the pin with some grease to help keep it there. Put the knuckle studs back on and slide the arm with bearing down onto the knuckle.
