Ok so I have search and search about shocks and springs for my 100. I already have a BIO front bumper and step sliders. I bought one of Mike’s BIO diff drops as well. I am going to be installing OME torsion bars. I bought a set of Bilstein HD stocks but have not installed them yet. I am 95% sure I will go with the 865 OME rear springs. I am 95% sure I will be running the Nitto Trail Grapplers in the 295-70-18 (34.57 by 11.73) size. I will tow a small enclosed trailer it’s about 8 feet wide by 15 feet long (weights1500 lbs empty). No rear bumper or 3rd row seats. This is my daily driver, I compute a whopping 2 miles to work each day. I know this is a big tire for my intended purpose but I like the look and the extra ground clearance of a larger tire. What I am looking for is the best compromise of ride quality and off-road capability. This rig will be used as an Expo/toy hauler/ daily driver. I already have a built up 80 that handles my serious trail duties. I want my 100 to be capable but to still have as nice a ride as possible (See, oxymoron).
My question is about the rear springs and the Bilstein shocks I already purchase. First question, “Will the 865 be able to handle the small trailer and it’s added tongue weight?” I am guessing it will be somewhere between 300 to 500 more lbs. I do not want to tow with the front end pointed up and would like to avoid using air bags if possible. So will these springs compress a lot of be fine in this situation? I know I can mitigate some of the tongue weight by adjusting how I load my trailer (i.e. heavy s*** to the back). With the stock springs it does not compress very much but I have only tow it when empty. Worst case scenario I could always add a 10 mm spacer or two to bring me back to level. If the rear ass is going to squat a lot I would just go with the 860 which should give me another ½ of lift and no stupid spacers.
So if the (865’s or 860’s) will work then will the Bilstein shocks work with these spring? I really don’t like the idea of losing suspension travel. I know on the front I am not going to gain any suspension travel with the stock arms so the Bilstein’s are fine. It’s the rear that I forgot about. Stock length rear stocks are not a good paring with 2 to 2 ½ inches of lift.
I know it’s a compromise but I already have the frickin’ shocks in my garage. So unless I am going to get a lot more travel do I need to return the Bilstein’s for say an OME? I have also read that some people are now unhappy with the Bilstein’s on the front with the OME torsion bars. Since they are still brand new I can return them and get a refund. If I did what says the group? OME or hit up Rad-flo that’s right around the corner from me? My only problem with the Rad-Flo’s is I am now going from the $360 I shelled out for the Bilstein’s to about grand for the Radflos. Not really in the budget right now but I could hold off and run the stockers until I get the funds.
Thanks for the impute.
(PS Shotts no need to start up with the OME L’s I have read all about them in every thread about shocks in the 100 section.)
