BFG AT 275/70/r18 on a stock 2019
Nashville
Can I fit BF Goodrich 275/75/18s on a stock 2019 with stock wheels? Do I need spacers or any suspension mods? Saw these tires today and it is what I want.
I have 275/70/18 KO2s with OME lift, Upper control arms, trimmed fender liner, and 20mm offset wheels: I occasionally get rubbing, so be advised you may have some rubbing completely stock.
You probably won't have any rubbing on stock offset wheels. They're barely 32" mounted on the vehicle.
Espalda,
Did you get the 275/70-r18 ‘s?
And did they rub?
General consensus here is that they fit on an unmodified truck, but there is enough noise from the other side saying one “might” need to do some massaging to the fenders that it gives me pause.
To be clear, I’m asking about a LC200. I think there is no disagreement on if a 275/70r18 will fit on an LX.
Ps. There is a disconnect with the heading and the op’s initial message. The heading is 275/70 and the body has 275/75. So I’m assuming the heading is what he meant.
Tried this size KO2s on my stock 2015 and had rubbing on suspension components just sitting with no articulation. Wasn’t worth the risk to me for zero benefit so went back to stock size.
Okay. Thanks for the input, Stonepa.
For what it’s worth, I have 275/65r18’s (so a slight step up in size) and I have no rubbing. So maybe that’s as large as a 200 can go on stock.
