I need a tool that will be best for reliably cutting .25" mild steel shape cuts, on a very regular basis. These shapes will range from squares (I am currently using my circular saw with a .125" or .1875" blade) to shape cuts that are irregular in form.
I have designed parts for the heavy equipment industry in the past using nesting software that interfaces with a cnc plasma / oxy/acetylene torch on a 96" x 240" water table, but I do not have access to such and now must figure out a better way of making these cuts in a small workshop (my garage) using more common tools.
I recently fabbed up a set of Metal Tech-style spacers and used everything from cut-off wheels on a 4.5" angle grinder to a sawzall with a steel blade; but these are all largely inefficient and are not the most practical means by which to move on to a more productive environment.
With the need to take it up a notch, which tool or tools would be best to cut up to .25" on a regular basis?
Thanks in advance!
Thanks in advance!
