Best rear cargo mat with 3rd row seats removed? (8 Viewers)
No changes, it will fit as long as your third row is removed.
Since then I’ve cut chunks of 1x4 to fit into the holes left behind by the third row mounting legs.. the mat covers them but there is a low spot in those locations due to the lack of carpet and padding. Works well.
Thanks for the confirmation - much appreciated! Out of curiosity what material did you use for the 1x4 pieces - wood?
Yep. Didn’t mean to say the pieces were 1x4 on the dimension to fit.. just that I cut up wood 1x4 into simple blocks that very roughly drop into each hole. I’ll try to get a picture today
Thought I would update ... the rear cargo area floor mat from Toyota fits perfectly. It also has small cut outs for the tie down points. It is bending up at corners because it is new but it should flatten out soon enough! Thanks again bloc!
Has anyone tried the 5-passenger liner that WeatherTech is now selling? 2020 Toyota Land Cruiser | Cargo Mat and Trunk Liner for Cars SUVs and Minivans | WeatherTech
Just bought an 08 and the third row is coming out as soon as I get a chance. I'm between the WeatherTech liner and the Heritage Edition mat. Since the WeatherTech liner is fairly rigid, I'm wondering if it'll sit flush, or if the third row mounting points will push up from below. OEM Heritage Edition mat is about half the price and it's well, OEM. WeatherTech is twice the price but seems like it would protect better... I'm torn.
This would be a tough one. I've had the 3-row WT mat, and I assume other than the cutouts it is similar construction. The taller sides would be really nice to reduce dirt/leaves/stuff slipping past the edge into the carpet.. but my WT mat was pretty bad about sliding around on the carpet because it didn't have any of the little pin protrusions on the bottom to keep it still. Try to slide anything somewhat grippy across it and it'll go right along with that object The HE mat has those protrusions all over and stays exactly where you put it.
If they were the same cost I'd probably go WT on account of the sides, but with it being so much more I'd lean HE.
PT206-60200-02
So I bought the OEM Australian cargo mat a while ago, but never got around to removing 3rd row from my 2015. Now bought a 2-row HE that came with the US stock rear cargo mat. The stock mat is okay, but it's of the "plasticy" rather rigid variety and very lightweight. The Australian mat is solid rubber, way heavier (easily 2-3x times). I like it better.
Also it does not come with pre-made holes for the tie downs (they are marked but not cut), so if one does not use tie downs, that's a plus.
Here is a pic in the cargo area of the HE:
Bringing this thread back from the dead. Can anyone confirm the Heritage Edition Cargo Matt (PT206-60200-02) would fit in a 2011 200 series? From what I can see in the photos, the youngest cruiser with one is a 2013.
^^^ why would it not? Nothing has changed in size.
You're probably right. Being a noobie, I didn't know if there were any rear cargo changes between '11 and '13. It's easily worth $84 to find out.
you'll be fine. i have the aussie mat above that i bought yrs ago before the heritage mat or whatever was even a thought in the usa. Besides it stinking forever like rubber, it's a serious mat. Spend the 85 bucks, well worth it.
To continue the resurrection from the dead, Husky seems to have one as well: Protect your Interior with WeatherBeater Floor Mats - https://www.huskyliners.com/WeatherBeater-Floor-Mats/2015/lexus/lx570/third-row-seats/yes-3rd-row Has anyone tried it? I use the Husky liners in my Tacoma because they are not as rigid/plastic feeling as the Weathertech ones. I was thinking about going with the Husky for the LX as well. but wasn't sure if anyone else had some experience with them.
The only one shown is for units with 3rd row installed.
Yes --- but if you look at it - it is meant to completely cover the holes left in the floor by the third seat (it goes up to the back of the second seat and has holes you have to cut if you are going to install the third seats)
