Any of the LC specific Aisan carbs from 70-74 will work, but there are a few things to consider.
1. Only the 70-73s worked with a cable, and that cable is similar to, but different to the one you currently have for the Rochester, so you will need a new cable as well.
2. Chances are your Rochester is bolted via and adapter directly to the intake manifold. You will need a stock phenalic spacer and 4 studs to adapt the stock carb back onto the intake.
3. Unless you are one of the select few that had an adapter made to fit the mouth of the Rochester into the stock air cleaner assembly, chances are fairly good that you do NOT have the stock air cleaner, and that will need to be acquired as well. Mounting said air cleaner requires loosening the two forward head bolts on the driver's side of your engine. Not a risk free proposition, not a deal-killer either. Just something worth mentioning.
4. No need to hold out for a non-US Aisan carb to get the vacuum advance port. It can be retrofitted. I do a lot of those during the rebuilding process at my shop, and I'm sure that Jim C. does it as well.
I can help you source all the parts if you like. You can call the shop number, linked below, for more info.
Hth
Mark A.
