Hi all,
I have a 1989 BJ73 (JDM RHD), on which I will shortly be replacing the water pump (the gasket is leaking, and it seems like a good idea to replace the pump while I'm at it). I'm not very experienced, but I have the shop manuals and it doesn't seem like a very complicated job...
A question, before I start, however:
When replacing the drive belt, the service manuals give different procedures according to the provenance of the vehicle. E.g.:
[Canada] Using a belt tension gauge, check the drive belt tension (Nippondenso BTC-20 or Borroughs No. BT-3373F)
Drive belt tension:
New belt: 145 +/- 25 lb
Old belt: 100 +/- 20 lb
[Others] Check the drive belt deflection by pressing on the belt at the points indicated in the figure with 10 kg of pressure.
Drive belt deflection:
Single belt type
New belt 8-12 mm
Used belt 11-16 mm
Double belt type
New belt 12-15 mm
Used belt 14-20 mm
Now, notwithstanding the fact that the FSM omits said diagram, what's going on here? My BJ73 is a Japanese import, so I assume the instructions for [Others] hold. What's the difference between the two sets of procedures? Must I go out and buy a belt tension gauge? How exactly does one apply 10 kg of pressure to a belt? By eyeballing it? While I'm in there, I'll replace the power-steering and AC pump drive belts too - do the same instructions hold?
Anything else that I should know about that comes to mind, feel free!
Cheers, and thanks for such a great resource.
Dave
Drive belt tension:
Single belt type
New belt 8-12 mm
Used belt 11-16 mm
Double belt type
New belt 12-15 mm
Used belt 14-20 mm
Dave
