this should be an easy question....
I'm on a road trip right now, everything is going great with the truck... except...
Today, we're at the coldest point on the trip and its around 0C. Both times I started the truck today the belt squealed - each time, reving it up to high RPM once stopped it.
Belt is 8mo.s old, tops, and has never squealed before, except for twice in the past when I changed coolant and probably spilled some on the belt.
The reason I'm asking is - the alternative explanation is that the squeal is from the water pump and my squealing in the past wasn't from spilled coolant, but from dying bearings. Is there a correlation between cold weather and a dying water pump.
I am carrying a new pump... but changing it would suck hugely, I have only hand tools and I already know the bolts on my fan are on TIGHT.
I'm hoping you're going to tell me how stupid I am, and to tighten the belt and be done with it.
