AVAILABLE NOW!
Bellfabrication.com
If you’re out of the loop on our tire carriers here’s what it is: a spare tire solution that lets you securely mount up to a 40" tire vertically in the cab of your cruiser.
The v1 worked well, but we saw room for improvements with both the user experience as well as ease of manufacturing and shipping. lets go over some of the main points.
We’re on the home stretch, ETA- one month. Production is well underway. parts are being welded and hardware is coming in. The next step after we get all these parts welded up is powder coat. Once we get all the pieces back from powder coat sporting their new texture black finish we will be getting kits assembled, hardware packs put together and everything boxed up and ready to ship.
Then we go live!
Were going to do a giveaway for one of the very first V2 models. details on that coming soon.
Bellfabrication.com
- Available for Driver or passenger side - this was a huge one. you’ve been asking for a passenger side option since the beginning, its here.
- works with tire sizes ranging from the factory 31" up to 40"- previously only accommodated 35" and up.
- 100% bolt in with no drilling required- The new version uses all factory bolt holes and more mounting plates for added strength.
- Black powder coat is now standard.
- we’ve added a molle panel option for those that want to utilize the space behind the tire for storage. this can be accessed through the slider window or even easier access for those of you using a gull wing window conversion. (molle panel is not required for normal use)
- Pricing- V2 will be $425, The optional molle panel is an additional $150
Then we go live!
