Aluminum still corrodes? Um, go read. It'll form a thin layer of whitish aluminum ozide a few molecules thick, cutting it off from the air and totally preventing further oxidation. Aluminum does not corrode.
Oh I have no clue.I have never seen it corrode personally. I know I have seen Stainless rust in half at plants ...but I am sure that was cheap s*** .Aluminum still corrodes? Um, go read. It'll form a thin layer of whitish aluminum ozide a few molecules thick, cutting it off from the air and totally preventing further oxidation. Aluminum does not corrode.
Well wait a minute. Yes it does. Especially if you have it mounted on steel and there is water involved or even low level electricity, I'm talking even static. It creates electrolysis which will basically means the process takes an electron from the weaker metal and add it to the stronger one. Effectively it will corrode the aluminum. BUT, putting a rubber/plastic barrier solves this issue. I would rock the aluminum so long as it was properly mounted because how much flowing water and flowing electricity does it actually get?
I have read, I've also witnessed and had to repair corroded aluminum. What you're saying is true in normal atmospheric conditions as a stand-alone item. Bolt aluminum to steel and you set up a galvanic battery once a little ambient moisture gets into the gap. Add in some minor sulphuric acid contamination and you no longer have a normal atmospheric condition, you have a hostile and aggressive corroding environment.Aluminum still corrodes? Um, go read. It'll form a thin layer of whitish aluminum ozide a few molecules thick, cutting it off from the air and totally preventing further oxidation. Aluminum does not corrode.
Not to continue a non-debate or split hairs further, but there should always be a gasket there anyhow, even with the stock tray (though there wasn't one there from the factory), as batteries don't like vibration particularly well and the gaskets act to an extent as a dampener, let alone a separator for the issue we're discussing. Do that and the aluminum corrosion issue is 100% moot.
