- Thread starter
- #21
So, after taking a second to actually think about this, and with your additional Rosetta stone interpretations, I fixed my response to him. There might be some tech in here yet!
''Now that I’m not just offended and can actually look at the facts presented, I’ll try to explain this, but you might not get it.
Your original comments said, “the battery is located very close to the radiator. Coolant can become very corrosive and this is also known as electrolysis (incorrect: Electrolysis is a metallurgical phenomena that occurs when two dissimilar metals are connected together. This phenomena causes an electron flow to move between the two dissimilar metals causing the weaker metal to fail.)
A battery that is covered in battery acid and corrosion will add to the (electrolytic capacity, NOT the…) level of corrosion in the cooling system. This corrosion (caused by electrolysis) can eat away at gaskets, seals and metal that (the current passes through, NOT…) it comes in contact with.”
This leads the reader to believe that because the battery is located near the radiator (irrelevant) a corrosive battery will add corrosive elements to the coolant (irrelevant and incorrect)What you talked about in your scientific explanation in your previous post was electrolysis and had nothing to do with what you stated originally.
While your scientific explanation is not 100% correct, the theory is kind of sound. Run your ohmmeter over the aluminum block to measure resistance, then stick the probes in some coolant. Tell me which has a higher resistance. The aluminum is a better conductor, even with old coolant. The moving coolant at operating temperatures may change this number though. However, the ground bolt does create a path for electricity. Passing eletrical current between dissimilar metals will cause corrosion.
Your original statement still doesn’t make sense to me, but I can see where you were trying to go after receiving the further clarification. Thanks for the explanation.''
