ARCHIVE Barnes 4WD Duracell AGM Battery Box
The Barnes 4WD Duracell AGM Battery Box is cut from 1/8" steel and formed for a snug fit around the common 34/78 Duracell battery size to prevent any movement. This battery box was designed to give you the most mounting options possible. Each battery box kit comes with the coated 5/16" hardware as well as lock nuts to prevent your fasteners from coming loose or corroding. These are made in the U.S. from U.S. Steel!
