ARCHIVE Barnes 4wd Axle Link Mount Coil Spring Combo and Axle Link Mount Shock Combo
Axle Link Mount Coil Spring Combo and Axle Link Mount Shock Combo​
When we are building a rig more time than not we find ourselves asking “where are we going to put all this stuff?" So we set out to try to find a way to most efficiently package our lower control arm brackets and our coil spring buckets and I think we hit the nail on the head! These are sold in pairs and come with a coil spring retainer. Here are some of the benefits that we incorporated into the design:
• Minimal axle tube needed to mount a control arm and coil spring
• Design keeps suspension joint as close to the axle as possible
• Mounting angles of 0, 10 and 20 degrees
• Bolt hole sizes of 9/16”, 5/8” and 3/4”
• The control arm bracket is made from one piece of steel to make it ultra strong
• Coil spring bucket can be mounted centered of the axle or you can adjust it ¾” if you do not want the coil spring directly over the axle
• Shock brackets be mounted centered of the axle or you can adjust it 1” if you do not want the shock directly over the axle
