That is actually a very important point. After such a catastrophic tire failure, an alignment check is in order.sounds like a problem they will find when re-aligning the vehicle.
So what are you saying? ... loosen the valve before changing the tire and tighten then afterward?
Well... my truck must be magic.
Every time I rotate my tires I jack each wheel up by the frame, take off the wheel/tire, put on a new wheel/tire and let it back down to the ground. I do this 4 times. Each wheel individually. Each jacked up by the frame. When jacking on the frame, each wheel is fully "dropped out."
Never had a lean.
Why don't I suffer the same KDSS weirdness being talked about here?
In off road situations, you are going to encounter all kinds of obstacles where only tire is articulating, and like @gaijin said if you work on your truck only jack up one (front for this example) wheel you're experiencing one wheel droop. I appreciate the effort @bloc is putting into this, but it just doesn't make sense. If a system like KDSS can cause major problems from jacking up a single wheel on a platform as robust as the 200, we're in trouble. But that's not the case as pointed out, and if it was the case your truck would be sitting a couple inches lower on one side after your experiment.
