Bad alternator?
When the battery voltage on my Sniper display reads 12.3 - 12.5 volts and flashes yellow, does this mean that the alternator isn't charging the battery?
Mine does that at an idle. I’ve tried a new regulator new alternator always same result. I believe it is just the amount of amp draw at idle. No need to worry
The above link takes you to and older post that is really will written. Describes how your ‘external’ voltage regulator works.
I think what you described above is normal. I run a Dakota Digital in an otherwise stock 1968 and has a volt meter vs. ammeter. And yes, sometimes it’s up around 14 volts, and sometimes at 12 volts….depending on the battery state of charge.
