Back driver door stuck
Texas
I was replacing the door lock actuator which is not a hard job but the door latch keeper that grabs the body on the edge of the door came loose and I reassembled the way I thought it went. A couple springs and a couple spinning shapes. Put back together and closed door. Now
It won’t open. Guess I didn’t put it back together right. Take it to body shop and see what they can do? Thinking I’ll have to dremel saw out
Is there a way to go from underneath fender and somehow disconnect the ubolt or something? Can’t think of a way to do this.
Argh.
I hadn’t clipped the door panel in so was able to wiggle it out. Pull on the rod connected to the door handle. Nothing. I think that latch is just stuck. I put springs or those two cams in wrong. Should’ve tested before I closed it!
Talked to body shop guy he said they’ll have to drill it or dremel from inside and I need to get a new latch for him to replace. Hope it works out.
Found this video somehow on IH8MUD and gonna try it later...here's hoping I can get my rear driver door open!
