Back door not closing because of inside bend locking button: easy fix (1 Viewer)
hj 60
JT1W0HJ6000960839
Netherlands Hengelo
Website
www.tapatalk.com
The HJ60 back door (hatch) was not locking properly, found I had to close the inside lock button manually so the lock would catch and hold the door shut.
But that is kind of stupid: all that out of the normal know how and I found the most easy fix: the button was slightly bend and had to much drag to "fall" to the lower/locking position.
The button is not hard plastic but rubber with iron inside.
Picture of normal SuPaFiXeD button, if your rear door/hatch does not close just check if the button is bend and has to much drag, if it does not go down the lock takes a big smash as it is not open but closed when the door is slammed shut.
file.php
