Wanted B specific clutch slave
Transplanted to SLC from Portland, Oregon
I am trying to find a B-specific clutch slave for the H55f that I want to install behind my 13bt.
Anyone know where I can get one?
Thanks - Adam
try ens industrial in saskatoon canada.
it would be a part they are still supplying or have in stock for BJ75's. I would imagine some of them are still underground.
Other than that, try a canadian toyota dealer. In fact I was able to purchase a clutch master cylinder rebuild kit for my 84 BJ60 from Napa. They had it in the system. One would guess they have a rebuild kit for the slave......
I have a slave cylinder from an early FJ60, which has larger mounting tabs then my bell housing has. I can probably fab a bracket to make it work, but I was trying to get an application specific item.
This thread would probably be better served as a tech thread in the diesel section. Do you want it moved? I can move it over easy enough...
That might be a good thing. It has been here a while, so maybe a move there will generate some more responses.
Captain:
I bought a clutch slave for the 3B/H55f combo from the BJ-73 from Japan 4x4 a couple months ago. No problems.
There are two different bolt hole patterns though, make sure you know which one you need.
Dan
I have MANY of these in stock. Just call and we'll get you set up with one.
Mention you saw this on 'Mud...
~John
