Australian Cruiser specs
OZCAL said:
I know you are looking forward to picking up a Landcruiser when you get down here, but you have a 1988 FJ 62, don't you? Just food for thought - 1988 is the last year, IIRC, that can be imported to Australia under the new laws. 1989 and newer can only be imported if they are truly a specialty car, like a Ferrari or something.
If your truck is in good condition, it might be worth it as used Landcruisers down here really run the gamut from pretty good condition to rusting through, and they are expensive compared to good condition used models in the US. It's just not the same as the US where even the worst maintained landcruiser still probably cleans up and runs well. They really get beat up here, because they are used as work trucks.
I brought down a shipping container full of household stuff in 2003, and decided against bringing my 1993 Landcruiser in pristine condition, 138K miles, all options. Sold it for $10,500. Turns out the same car would have cost $20-25K to replace down here, if I could even find one with a factory sunroof, factory window tint and a few other non-mechanical but expensive and important "daily-driver" items. I really kick myself sometimes, when I get in my RHD 80 down here with no sunroof, peeling after market tint, dealer A/C, no cruise control, no rear heat...
Anyway I could have put the Landcruiser in the 40' shipping container for a few hundred dollars (at that time, it might have been possible to get a 93 car in, but if not that, my '69 Porsche 912, which I regret not bringing even more, but that's another sad story :frown: ). My point is that if you are going to spend a few thousand on a shipping container, and you already have a good truck, even though you'll have your steering wheel on the "wrong" side, it's worth considering.
I've gotten long-winded - sorry about that.
David
Ozcal,
Thanks for the post. I'd been thinking of going to Australia and buying a cruiser for touring the outback. I'd assumed prices there similar to the USA.
Looks like I'll need a re-think.
Kalawang
azaussie said:
As I recall reading in one of the Aussie Mags the 5 speed that came in the early 60 series trucks was just a 4 speed with an extra cog added and it was not very strong. But over on the 60 board guys rave about this H55F tranny and I was wondering if it is the same one that the Aussie mag bashed or if it is a different one. :confused:
Well, the different experiences with the H55 in the two continents is most likely due to the different driving conditions. In Oz, they're exposed to much higher distances under much rougher conditions. They are also installed in a much larger number of landcruisers. The higher amount of use, distance and number of vehicles, is more likely to expose the weaknesses of a part.
There are other areas that the Aussies encounter that other countries or regions don't often see. Cracking IFS 100 series arm mounts, 1HDT big end bearing delamination and transmission output shaft spline wear come to mind.
Dave
Hj60
I would be interested in something like this HJ60 for myself. http://www.autotrader.com.au/photodisplay.asp Sorry, don't seem to be able to gfet the link to work but below is how the ad reads.
"TOYOTA LANDCRUISER 4WD, 1990 model white wagon, 4.0ltr, 5sp manual, 191000 kms, diesel, power steering, towbar, rego, regularly serviced, excellent cond -$8995"
In US dollars it would be about $6,750 which does not seem too expensive for the diesel and 5 speed. Does the HJ60 come with the 12HT or something else?
azaussie said:
Crusher, This rig looks just like my FJ62 so would that make it a HJ61?
In late 87 every 60 series got the four headlight grille...
Dave
april 1989
or
march 1988
i can not make out the digits properly...
