For Sale Australia: 1974 fj40
FJ40 - $13000 ONO
Pictures can be found here
Looking to sell this to purchase a BJ42, don’t have the room for both.
If you have a BJ42 up for grabs, happy to swap with cash adjustment at either side where necessary.
**Interstate buyers, I am happy to help you out by taking to the depo, etc.
Price is without rego & RWC, however, call/text to discuss rego.
Engine & Transmission:
Holden 308 5L V8 rebuilt 2 years ago by R&N Superchargers
New manifold, pistons, piston ring, new cam and lifters –crow cams 666 set up, water pump, sump, dizzy and holly carb.
Hi-Torque Gear Reduction Starter Motor
3” mandrel bend snorkel with sealed air cleaner in carby
Toyota factory FJ40 4 speed and transfer case
New 2 1/2” straight through exhaust by Truflow exhaust put in under 150km ago
Suspension & Brakes:
EFS Shocks and 2” lift EFS leafs
Snake Racing Extended Shackles (2” lift)
2” body lift
Front disc brakes
All shoes and wheel cylinders been REPLACED with new ones 100km ago
Brand new drums put in 100km ago
Brake Master Cylinder been replaced 100km ago
Brakes serviced by Pedders Suspension
Handbrake shoes need replacing, have a set ready to be put in
Differentials & Steering:
60 Series Land Cruiser differentials
Front & Rear ARB Air Lockers
On-Board ARB Air Compressor for air lockers & inflating tyres
60 Series Land Cruiser tilt column steering with headlights, indicators and window wipers on column
60 Series Land Cruiser power steering
Piranha Front and Rear Diff breathers
Wheels:
4 x TSL 37” Boggers on 15” rims 37x13x15”
4x Mudstar 33” Mud Terrain on 15” rims 33x12.5x15”
Plenty of tread on both set of wheels
Audio:
Alpine CDA-9872e Head Unit
Cadence 12” Subwoofer
Audioline AL-4200 800W 4CH AMP
2x Sony 6x9 boxed speakers
Misc:
Custom front and rear bar with removable recovery points rated ~9000lbs @ each recovery point
Tow hitch receiver at rear with Narva trailer point for lights
80 litres Long Range fuel tank located at rear
Eureka Sidesteps
Eureka sports roll cage with seatbelt anchor points with certificate
Autotecnica Monza ADR Approved Bucket Seats
Waeco centre console cooler (hot and cold) with cup holders
UHF Radio
MOMO gothem steering wheel
Optima dry cell battery with isolator switch
ARB air compressor with outlets on each side of the 4WD to pump tyres
Autometer dash, Speedometer, Tachometer, Oil Pressure, Water Temp, Fuel, Voltmeter
Rear LED in boot
Rear draws for storage and will come with extra parts –belts, water pump, fuel pump, alternator, etc
All oils (gearbox, engine, diffs etc) have also just been changed.
I have receipts for most modifications and will provide upon sale.
I can also lower the price if sold without the 37" TSL Boggers.
Please, no time wasters, serious buyers only.
