- Joined
- May 31, 2009
- Messages
- 78
- Thread starter
- #21
Without the wiring diagrams for an '06, I'm no help. My 99 diagrams aren't necessarily identical so I don't want to guess and lead you astray.
The phantom ground wire (the one to avoid once you bypass the factory amp) on my 99 was brown. I'm guessing that's the loose lead you see in your pics.
My apologies, I always assume everyone on here that's not me is an expert and knows everything without further reference.
Here is the information I pulled from the tlcfaq.com site that I believe is for a 2004 that seemed to match well with what I had:
The second image references the black wire (SGND???) I was curious about in my previous post, which I was wondering if it's likely tied in to the four speaker signal positives from the HU with the RCAs, and that it's okay that it is just hanging out like that?
The third image references the brown (GND...system ground???) wire I was curious about in my previous post, which would likely be the same as what you said is the phantom ground wire to avoid during a bypass, so I am now assuming it's fine left as is?
