SOLD Atlanta GA 2001 LX470
Year
2001
  1. LX470
2001 LX470 with 241,000 miles in Riverock green mica.
Asking $9,000.
I have owned this 100 since 2013, I am the second owner the first owner lived in Richmond Virginia.
On the way home after my purchase the transmission failed, so had it towed home and had a rebuilt Toyota transmission installed at 148,000 miles. I've had no issue with the transmission since then.
During my ownership it has been serviced by a Toyota Lexus shop here in Buford GA called Garrards Japanese Automotive.
Other than regular oil changes I had a major service work done at 193,000 miles including:
  • timing belt
  • drive belts and pulley
  • radiator
  • thermostat
  • water pump
  • radiator housing
  • left and right valve cover gaskets
  • spark plugs and wires
  • suspension fluid flush
  • power steering flush
  • heater t and hoses
  • differential fluid front and rear
At 212,000 miles the front and rear brake pads and rotors replaced.
AC Condenser replaced at 233,000 miles last summer, blows cold!
At this time the only items that I am aware of that need attention are the tires and battery.
The tires are LT Michelin LTX MS2 that were installed almost 80,000 miles ago but they still have tread left.
The battery is at the end of it's expected life but still has a strong charge.
The rims are the Tundra 18" that were put on when I installed the Michelin tires.
I personally installed the pioneer double din head unit that has apple car play and android auto plug and play.
I also installed two new amps, one for the 4 door speakers and one for the sub woofer, new speaker wire and all new Alpine speakers - sounds great.
I removed the running boards and installed the front mud guards. I still have the running boards.
The roof rack had one of the post caps fall off, couldn't find a replacement so I took it off - still have the remaining parts.
This 100 has basically been a family car, I've never taken it off road.
Very clean looking. Glws. Question, unrelated. When you remove the roofrack, do you have to go under headliner, or can that be done all externally? Appreciate any info. Thanks.
