ATF flush with screen/filter?
i will be doing a complete flush for my lx 07 (second time) and first time , I didn't replace AT screen/ filter.
Read few threads but no one mentioned screen/ filter replace!!
Should I buy the screen and replace it or no?
There's an O-ring you'll need to replace on the oil strainer (screen) after cleaning. Make sure available before you begin.
The older pre 2003 transmissions have gaskets that only come with new oil strainer. You'll also need new pan gasket.
This is not a recommend procedure, but one us over-maintainers like to do.;)
Note:
39in-lbf (INCH) on pan bolts.
7ft-lbf on strainer bolts
15ft-lbf drain plug with new washer (gasket)
29ft-lbf refill plug with new washer (gasket)
This is not a recommend proceed, but one us over-maintains like to do.;)
Note:
Thanks 200lc.
I have a AT shuddering after radiator replace and TB, guess low fluid, so I decided to do a complete flush and it seems to solve the shuddering issue.
